Extralite HyperFront Thru Axle Adapter
$21.00
SKU:
099DD031
This pair of simple adapters are machined from lightweight and strong delrin thermoplastic, and are designed to adapt an Extralite Hyperfront Disc hub from 15x100 to 12x100 thru axle standard. This allows the Hyperfront to by used on many road disc, cyclocross, and gravel forks that use this smaller diameter axle standard. The press-fit adapters are easily installed by hand into the existing axle, with no tools required. The pair of adapters add a mere 2.5 grams to the weight of the hub. These are designed to fit the Extralite HyperFront hub exclusively.
Weight2.5 grams
Compatible HubsExtralite HyperFront only
