Extralite Hyper Bottom Bracket Cups
Article number: | 019-02-01 |
Extralite Hyper Bottom Bracket cups are the perfect light weight cup upgrade for cranks that have 30mm spindles that utilize 6806 bearings. Additionally, these are the cups you will want to get if you have an Extralite QRC 3 Crankset.
Select the appropriate bottom bracket cup set from the drop down menu. Each selection comes with 2 bottom bracket cups. If you need help figuring out which bottom bracket is right for your setup then contact us, and we will be happy to assist you.
Cup Set | Approx Weight Per Cup Set |
BSA | ~21g |
BB30 | ~21g |
BB386 EVO | ~21g |
BB Right 42 (Direct Fit) | ~24g |
T47 External | ~21g |
