Extralite ExtraBolt 15.4 Sram Eagle Pulley Set
$66.00
SKU:
1CCCC6BC
This aftermarket pulley set from Italian manufacturer Extralite is designed to fit Sram's series of 12-speed Eagle derailleurs. At 14 grams per pair, these lightweight machined Delrin plastic pulleys will save a full 12 grams over Sram's stock XX1 Eagle derailleur pulleys. The teeth of Extralite's pulleys feature the same phased narrow/wide design of the stock pulleys to ensure superior chain retention on modern 1x12 drivetrains. Both pulleys in this set (12 tooth upper and 14 tooth lower) are fitted with two high quality ABEC 5 micro cartridge bearings with low friction seals.
Weight per Set14.1 grams
Materialdelrin
BearingsABEC 5 micro cartridge (4 total)
Derailleur CompatibilitySram Eagle 12 speed
