Extralite BlackLock Rear Thru Axle
UPC:
Default Tax Class
$88.00
With the rising popularity of thru axle designs being used by nearly every major fork and frame manufacturer, companies like Extralite have immediately filled in the niche for quality performance tuned parts that many discerning cyclists desire. With this in mind, Extralite has produced the Black Lock, a surprisingly lightweight thru axle skewer. Utilizing a unique externally tapered surface and precise dimensioning, Extralite is capable of shaving as many grams as possible while still maintaining a sturdy design that’s tough enough to withstand the abuse of a typical mountain bike ride. To ensure proper installation that’s as smooth as possible, each Black Lock comes with a self lubricating brass washer that is designed to reduce friction between the skewer and frame/fork.
Each Black Lock skewer is simply installed like your typical OEM skewer, using a 6 mm allen wrench at a torque rating of 10 Nm. It is highly recommended that threads are greased prior to installation to ensure a proper torque rating.
Check out our blog for better info about which thru axle to use
ModelHub CompatibilityInterfaceLengthThread PitchThread LengthWeight
12.1 - E-thruTA 12 x 142Flat172mm12 x 1.5 mm18.3mm29g
12.1B - E-thru BoostTA 12 x 148 BoostFlat178mm12 x 1.5 mm18.3mm31g
12.2 - Specialized X12TA 12 x 142Tapered161mm12 x 1.0 mm17.2mm29g
12.2B - Specialized X12 BoostTA 12 x 148 BoostTapered166mm12 x 1.0 mm17.2mm30g
12.3 - MaxleTA 12 x 142Flat176mm12 x 1.75 mm19.2mm30g
12.3B - Maxle BoostTA 12 x 148 BoostFlat182mm12 x 1.75 mm20.0mm31g
12.4 - ScottTA 12 x 142Flat168mm12 x 1.0 mm17.2mm29g
12.4 RA - Scott Road pre-'20TA 12 x 142Flat158mm12 x 1.5 mm13.0mm27g
12.4 RB - Giant RoadTA 12 x 142Flat163mm12 x 1.5 mm13.0mm28g
12.4 RC - Scott Road '20TA 12 x 142Flat168mm12 x 1.5 mm13.0mm29g
12.4B - Scott BoostTA 12 x 148 BoostFlat172mm12 x 1.0 mm17.2mm29g
Material7075 T6 aluminum
Tool Fitting6mm Hex
Recommended Torque8-10Nm
Rear Thru Axle
Boost Rear Thru Axle
Style:
Boost
Style:
Road Disc
Style:
Mountain
Interface:
Flat
Interface:
Tapered
Diameter:
TA 12 x 142
Diameter:
TA 12 x 148 Boost
Fits:
12 x 1.0 mm
Fits:
12 x 1.5 mm
Fits:
12 x 1.75 mm
Aluminum
Size:
158 mm -182 mm
