Extralite BlackLock Front Thru Axle
UPC:
Default Tax Class
$66.00 - $88.00
SALE - 20% off (15.1 & 15.5)
With the rising popularity of thru axle designs being used by nearly every major fork and frame manufacturer, companies like Extralite have immediately filled in the niche for quality performance tuned parts that many discerning cyclists desire. With this in mind, Extralite has produced the Black Lock, a surprisingly lightweight thru axle skewer. Utilizing a unique externally tapered surface and precise dimensioning, Extralite is capable of shaving as many grams as possible while still maintaining a sturdy design that’s tough enough to withstand the abuse of a typical mountain bike ride. To ensure proper installation that’s as smooth as possible, each Black Lock comes with a self lubricating brass washer that is designed to reduce friction between the skewer and frame/fork.
Ordering
The Extralite Black Lock is available in configurations to fit most modern forks:
Each Black Lock thru axle is installed using a 6 mm allen wrench at a torque rating of 10 Nm. The tool fitting is located on the threaded side of the axle. It is highly recommended that threads are greased prior to installation to ensure a proper torque rating.
Check out our blog for better info about which thru axle to use
ModelHub CompatibilityInterfaceLengthThread PitchThread LengthWeight
BlackLock 12.5TA 12 x 100Flat120mm12 x 1.5 mm12.5 mm20g
BlackLock 12.5ATA 12 x 100Flat116mm12 x 1.5 mm12.5 mm19g
BlackLock 12.5BTA 12 x 100Flat125mm12 x 1.5 mm14 mm21g
BlackLock 15.1TA 15 x 100Flat143mm15 x 1.5 mm8.7 mm25g
BlackLock 15.2TA 15 x 100Flat143mm15 x 1.5 mm16.2 mm27g
BlackLock 15.3TA 15 x 100Flat146mm14 x 1.5 mm14.2 mm27g
BlackLock 15.3BTA 15 x 110 BoostFlat156mm14 x 1.5 mm14.2 mm28g
BlackLock 15.4TA 15 x 100Flat147mm15 x 1.5 mm12.2 mm27g
BlackLock 15.4BTA 15 x 110 BoostFlat156mm15 x 1.5 mm12.2 mm29g
BlackLock 15.5TA 15 x 100Flat139mm15 x 1.0 mm11 mm27g
Material7075 T6 aluminum
Tool Fitting6 mm allen
Recommended Torque10Nm
Front Thru Axle
Boost Front Thru Axle
Style:
Boost
Style:
Mountain
Style:
Road Disc
Interface:
Flat
Diameter:
TA 12 x 100
Diameter:
TA 15 x 100
Diameter:
TA 15 x 110 Boost
Fits:
12 x 1.5 mm
Fits:
14 x 1.5 mm
Fits:
15 x 1.0 mm
Fits:
15 x 1.5 mm
Aluminum
Size:
116 mm - 125 mm
Size:
139 mm - 156 mm
