Extralite BlackLock Front Thru Axle
$88.00
* Unit price: $88.00 /
Article number: 019-03-04
Availability: In stock (1)
With the rising popularity of thru axle designs being used by nearly every major fork and frame manufacturer, companies like Extralite have immediately filled in the niche for quality performance tuned parts that many discerning cyclists desire. With this in mind, Extralite has produced the Black Lock, a surprisingly lightweight thru axle skewer. Utilizing a unique externally tapered surface and precise dimensioning, Extralite is capable of shaving as many grams as possible while still maintaining a sturdy design that’s tough enough to withstand the abuse of a typical mountain bike ride. To ensure proper installation that’s as smooth as possible, each Black Lock comes with a self lubricating brass washer that is designed to reduce friction between the skewer and frame/fork.
INSTALLATION
Each Black Lock thru axle is installed using a 6 mm allen wrench at a torque rating of 10 Nm. The tool fitting is located on the threaded side of the axle. It is highly recommended that the threads are greased prior to installation to ensure a proper torque rating.
Model Interface Length Compatibility Thread Length Weight
T/A 12 x 100 mm
12.5 Flat 120 mm 12 x 1.5 mm 17 mm ~20g
12.5A Flat 116 mm 12 x 1.5 mm 17 mm ~19g
12.5B Flat 125 mm 12 x 1.5 mm 14 mm ~21g
12.5E Flat 122 mm 12 x 1.75 mm 12 mm ~20.5g
12.5F Flat 120 mm 12 x 1.5 mm 12.5 mm ~20g
12.5G Tapered 114 mm 12 x 1.0 mm 12.5 mm ~19g
T/A 15 x 100 mm
15.3 Flat 146 mm 14 x 1.5 mm 14 mm ~26g
15.4 Flat 147 mm 15 x 1.5 mm 12 mm ~26.5g
BOOST T/A 15 x 110 mm
15.3B Flat 156 mm 14 x 1.5 mm 14 mm ~28g
15.4B Flat 156 mm 15 x 1.5 mm 12 mm ~29g
Material 7075 T6 Aluminum
Tool Fitting 6 mm Hex
Hub Compatibility T/A 12 x 100 | T/A 15 x 100 | T/A 15 x 110
Recommended Torque 8 - 10Nm
15.4 (147mm)
  • Rock Shox
    • SID
      • SL
        • Ultimate, Brain , Select +, Select (2021)
      • Ultimate (2021)
      • Select / Select + (2021)
      • WC, XX, RCT3, RLT, RL (2012-2015)
    • RS-1 (2015-)
    • Reba RLT, RL (2012-2015)
    • Pike DJ, RC, RCT3 (2014-2015)
    • Revelation WC, XX, RCT3, RLT, RL (2014-2015)
  • Santa Cruz
    • Stigmata
15.4B (156mm)
  • Rock Shox
    • SID RL, RLC, WC, Brain Boost (2016-2020)
    • Reba RL Boost (2016-2020)
    • Lyric RC, RC2, RCT3 Boost (2016-2020)
  • NOT COMPATIBLE WITH THE 2021
    • SID, SID SL (Ultimate, Brain Select=, and Select)
    • RS-1
