The popularity of our best-selling ESI grips is based on several factors. The most notable would be the excellent comfort, cushioning, and damping these grips provide. Beyond their comfort and performance aspects, as these grips are manufactured from silicone they are longer lasting and upkeep/cleaning is easier. Another advantage to the silicone material is that it doesn't become sticky when exposed to extensive sunlight. Additionally, these grips boast very respectable weights without compromising functionality. The consistency of the material and diameter make them ideal for trimming to shorter lengths where necessary.
The Extra Chunky version of the ESI Grips features a grip diameter of 34mm for added comfort. For those looking for the thinnest and lightest version of the ESI grips, the ESI Racer’s Edge can be found here. For grip that comes right in between this Extra Chunky version and the Racer’s Edge in terms of diameter and weight, the ESI Chunky can be found here.
ESI grips are designed to fit tightly for maximum security and rider safety. To ease installation, we recommend lightly coating the inner diameter of the grip with isopropyl alcohol prior to installation. The alcohol acts as a lubrication that will quickly evaporate once the grip is installed.
Weight | 80 grams per pair |
Length | 130 mm |
Outer Diameter (Installed) | 34 mm |
