10% Off all 3T Components!
ENVE Smart System 6.7 Rims
Tire Size700c
Clincher Weights
Front 60mm520 grams
Rear 70mm542 grams
Tubular Weights
Front 60mm480 grams
Rear 70mm530 grams
Rim Depth
Rim Width
Front 60mm26mm
Rear 70mm24mm
Front 60mm535mm
Rear 70mm517mm
Product Manuals
Enve Valve Extender Installation Video
Full Enve Owners Manual
ENVE Smart System 6.7 Rims Clincher, 60 mm Front, 20 Hole $975.00  1 Remaining
ENVE Smart System 6.7 Rims Clincher, 70 mm Rear, 24 Hole $975.00  1 Remaining
ENVE Smart System 6.7 Rims Tubular, 60 mm Front, 20 Hole $875.00 In Stock
ENVE Smart System 6.7 Rims Tubular, 70 mm Rear, 24 Hole $875.00 In Stock
When ENVE and Smart first teamed up their goal was a complete set of full carbon fiber rims that were fully optimized through extensive wind tunnel testing for the best aerodynamic response and stability in real world conditions. The resulting front and rear specific deep section rims feature two separate profiles; the front slightly wider and slightly shallower than the rear. The Smart System rims were designed to interface with both the active rider and various modern frame designs. Additionally, ENVE heavily focused on wheel stability in varying wind conditions to ensure efficiency and rider safety.
In just a few short years, ENVE has emerged as one of the industry's "heavy hitters," and has used the full capability of their engineering and manufacturing prowess to bring the design of their Smart System wheels to life. These 6.7 series rims represent ENVE's best aerodynamic wheel option, with cross sections that yield lighter, more stable wheels with very little compromise in aerodynamics. These rims are intended for use in virtually all weather conditions, terrains and disciplines. Using their proprietary molded spoke hole design, ENVE ensures maximum strength at the spoke-rim interface while allowing higher spoke tensions that improve wheel reliability. Smart System rims also feature an all new textured sidewall design that improves braking response and thus rider safety. In a departure from their traditional bold decals, ENVE has chosen understated and elegant black decals that vary in appearance depending on light conditions.
ENVE Composites is an American company committed to American design, engineering, and manufacturing. ENVE Smart System rims are produced with pride in Ogden, Utah, USA.
Each rim purchase includes brass internal nipples, an ENVE valve extender, and a pair of ENVE's proprietary brake pads.
Available exclusively through Fair Wheel Bikes - custom colored ENVE decals! To order your custom decal set, simply purchase a decal upgrade for each rim set purchased. Each decal upgrade includes 12 decals for a front and rear rim set. Decals are not available separate from rim purchases. Rims are shipped with decals applied. Standard rims include the stock black and white ENVE Smart System decal.
Shipping ENVE Internationally
We recommend that wheels built with ENVE 6.7 rims be assembled by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in hub and spoke selections. Please contact us directly or submit a custom wheel build request here.
CyclingNews: Enve Wheels - Can "Aero" Get Any Quicker?
