Enve SES Carbon Aero Road Stem
$300.00
Developed through extensive aerodynamic testing and with feedback from the WorldTour riders of Team Dimension Data for Qhubeka, the Enve SES Aero Road Stem places itself among the most advanced, fastest bicycle stems on the planet. Beyond its clever innovations and sleek design features, the Aero Road stem is optimized for the best possible ride quality that its carbon fiber composition can provide: high-frequency vibration damping for all day comfort, combined with impressive stiffness for confident control and handling.
Understanding that aerodynamics in cycling are largely affected by rider position, Enve developed an adjustable steerer tube interface for their Aero Stem to allow body position to be fine-tuned for the best possible aerodynamic efficiency. This interface uses a set of two interchangeable shims to allow micro adjustments in both the stem's length and its rise. The first shim sets the rise at either -7° or -17°, while the second shim sets the angle at -12° with a length options of +2.5mm or -2.5mm. The included top cap, while requiring the removal of any excess steerer tube, completes the stem's smooth lines and aerodynamic profile.
Both the steerer tube and handlebar clamps are designed to fit the current industry standards of 1-1/8" and 31.8mm, respectively. This stem is ideally paired with Enve's SES Aero Road Handlebar, but is compatible with nearly all modern road handlebars.
Use of a torque wrench is highly recommended when installing any ENVE stem. Each bolt rated to a maximum torque of 5.5 Nm. An Assembly compound such as Park Tool's Supergrip Compound will aid in assembly by increasing friction in the clamp area, thus reducing necessary bolt torque.
Shipping Enve Internationally
We no longer ship Enve products outside of the United States. We apologize if this inconveniences you.
Installation Video
Weights (claimed)
100mm170 grams
110mm175 grams
120mm180 grams
130mm185 grams
140mm190 grams
Handlebar Clamp Diameter31.8mm
Steerer Tube Diameter28.6mm (1-1/8")
Stack42.5mm - 12° shim
45.5mm - 7°/17° shim
Rise-12° with length shim
-17°/-7° with angle shim
Body Materialcarbon fiber
Faceplate Materialaluminum
Hardware Materialtitanium
Recommended Useroad, triathlon
Stems
Size:
100mm
Size:
110mm
Size:
120mm
Size:
130mm
Size:
140mm
Style:
Road
Diameter:
31.8mm
Carbon
