Enve SES 7.8 Tune Mig / Mag Wheelset
ENVE 7.8 Rim
Designed and manufactured in Ogden Utah, the ENVE 7.8 rim seamlessly integrates with aerodynamic framesets, and is touted by Enve as their finest aerodynamic rim option for race day roadies, and die-hard triathletes. Utilizing Enve’s venerable asymmetric rim profile, the SES 7.8 is faster than the 8.9 of old, while handling more like a 6.7 setup. Ideally paired with 25c tires for their increased volume and superior handling characteristics, a slightly wider tire is also more aerodynamic when paired with a SES Wheelset. Additionally equipped with Enve’s redesigned brake track, the SES 7.8 boasts impressive increases to stopping power in both dry and wet conditions, while simultaneously being 100% tubeless compatible. Like all Enve rims, the 7.8 features proprietary molded spoke holes, resulting in a drastic increase in wheel strength.
Tune Mig 70 / Mag 170 Hubset
We've been selling, building, and servicing Tune hubs longer than any other company we've worked with. What started as a boutique addition to our internet shop has slowly become our go to lightweight hub for a variety of wheel builds. The very serviceable Mag 170 rear hub features a simplistic three pawl ratchet system combined with an alloy 17mm axle for a total weight of 170g, as the name implies. The Mig 70 shares the same 17mm axle and 6803 bearings as the Mag 170 with a weight of 75g for a total hubset weight of 245g. This makes the Tune Mig / Mag hubset an affordable, reclaimable, serviceable, light weight pairing to the 7.8 rims. The ENVE 7.8 Tune Mig / Mag wheelset is a supremely aerodynamic option for all riders, capable of traversing hilly race courses and all day training rides, while ditching superfluous weight and complexity.
Ceramic Bearing Upgrades for Your Wheelset
If you're looking for every bit of performance from your wheelset ceramic bearings are a detail that should not be overlooked. All Ceramic Bearing upgrades are performed here at Fairwheel Bikes using the highest quality HSC ceramic bearings. A full set of ceramic bearings will save you around 10 grams, but the true performance gains come from the precious watts that are saved over a standard steel bearing.
Sapim CX-Ray Spokes
Last, but not least, Sapim CX-Ray spokes are the go-to spoke for many of the world’s elite wheel manufacturers like Zipp, ENVE, and Reynolds. Due to Sapim’s proprietary forging process, the CX-Ray possesses the benefits of high rigidity and an aerodynamic profile with none of the performance penalties associated with lightweight spokes. In fact, each Sapim CX-Ray spoke has a tensile strength of up to 50% more than a straight gauge spoke and a fatigue life of nearly 3 times as long. That means a more durable wheel that will see you over the mountains and through tough sprints for longer than any other wheel in its class.
Sapim Drive Side CX-Sprint Spoke Option
For our stronger, more powerful riders we oftentimes will lace our rear wheels with CX-Sprint spokes on the drive side. Putting a slightly heavier and stronger spoke on the higher tension drive side better counteracts the increased stresses drive side spokes encounter, creating an overall stiffer and more durable wheel. The CX-Sprint spoke is the "bladed" version of the Sapim Race spoke (1.8mm), while the CX-Ray is a modified Laser spoke (1.5mm). The 20% extra material at the spokes thinnest part is something that lighter riders will not notice but will create a stiffer wheel for those who need it. For the Sapim CX-Sprint upgrade simply contact one of our wheel builders (information below) or add a note into your order with your wheelset.
Custom Wheels
If you're looking for a custom version of this wheelset or want to discuss if this is the right set of wheels for you we are happy to talk. Please contact us directly (Phone: (520) 624-3045, Email: feedback@fairwheelbikes.com) or contact us via email on this form.
Spoke Type j-bend
Freehub Body Options Shimano Road, Campagnolo, SRAM
Axle Compatibility Quick Release
Warranty Rims: Five Year
Hubs: Two Year
Wheelset Weight
Tubular, g (Front / Rear) 611 / 758
Clincher, g (Front / Rear) 760 / 910
Tubular Rim Specifications
Tire Compatibility Tubular
(25mm recommended width)
Weight, grams (Front / Rear) 436 / 468
Drilling 20 / 24
Depth, mm (Front / Rear) 71 / 80
External Width, mm (Front / Rear) 29 / 27.5
Clincher Rim Specifications
Tire Compatibility Tubeless
Weight, grams (Front / Rear) 585 / 620
Drilling (Front / Rear) 20 / 24
Internal Width (Front / Rear) 19 / 19
