ENVE SES 6.7 Carbon Clincher Tubeless Rim
$1,095.00
The SES 6.7 Rim embodies the pinnacle of performance, blending weight savings, stability, aerodynamics, and rolling efficiency. Aerodynamically optimized for a 27mm tire, it delivers unparalleled speed, confidence, and control in real-world riding conditions. Featuring a 23mm internal rim width, it excels with road tubeless setups, offering superior rolling efficiency and speed. With ENVE's Wide Hookless Bead design, it ensures tubeless reliability and reduces the risk of pinch flats, enhancing the overall riding experience.
Opt for our expert wheel-building service for top-notch rim assembly. We offer valuable advice on hub and spoke selection. Contact us for personalized assistance.
 Model SES 6.7 Legacy 5.6 AR Legacy 7.8 AR
  Front Rear Front Rear Front Rear
 Rim Depth 60 mm 67 mm 54 mm 63 mm 71 mm 80 mm
 External Width 30 mm 29 mm 28.75 mm 28 mm 29 mm 27.5 mm
 Internal Width 23 mm 19 mm 19 mm
 Weight ~430g ~449g ~450g ~470g ~492g ~521g
SES 6.7 Specifications Front Rear
ERD
538 526
Hole Count 24 hole
Bead Type Hookless
Tire Type Tubeless Ready
Minimum Tire Size 700 x 25
Valve Stem Length* 80 / 85 mm
Tubeless Tape Width* 26.5 mm
TIRE COMPATIBILITY
INCLUDED
Tubeless Kit (6.7) - Tape / Valves*
Brass Nipples
Valve Extenders (55 mm)
