ENVE SES 4.5 Carbon Clincher Tubeless Rim
Article number: | 15- |
ENVE's SES 4.5 Rim is designed for speed and confidence across various terrains. Its 25mm internal rim width ensures precise handling, particularly on technical courses, while optimizing road tubeless performance minimizes the risk of pinch flats. This aerodynamic carbon fiber rim is a game-changer for fast-paced rides, offering unmatched reliability and efficiency.
Trust experienced wheel builders for top-notch assembly of ENVE rims. Opt for our expert wheel-building service and receive valuable advice on hub and spoke selection. Contact us for personalized assistance.
Model | SES 4.5 | Legacy 3.4 AR | Legacy 4.5 AR | ||||
Front | Rear | Front | Rear | Front | Rear | ||
Rim Depth | 49 mm | 55 mm | 39 mm | 43 mm | 49 mm | 55 mm | |
External Width | 32 mm | 32 mm | 31 mm | 30.5 mm | |||
Internal Width | 25 mm | 25 mm | 25 mm | ||||
Weight | ~425g | ~435g | ~387g | ~394g | ~440g | ~450g |
SES 4.5 Specifications | Front | Rear | |||
ERD |
558 | 547 | |||
Hole Count | 24 hole | ||||
Bead Type | Hookless | ||||
Tire Type | Tubeless Ready | ||||
Minimum Tire Size | 700 x 27 | ||||
Valve Stem Length | 66 mm | 72 mm | |||
Tubeless Tape Width | 29 mm | ||||
TIRE COMPATIBILITY | |||||
INCLUDED | |||||
Tubeless Kit - Tape / Valves (4.5) | |||||
Brass Nipples | |||||
Valve Extenders (55 mm) |
