Categories
ENVE has been working hard on expanding their SES platform to meet the needs of riders across multiple disciplines. Expanding their scope into the endurance road market, Enve has developed the 4.5 All Road, an aerodynamic rim set optimized for 28-30 mm wide road tires. These rims are a direct response to the modern evolution of the road bike, with disc brake specific design and wider rim beds for larger tires. Beyond the obvious comfort factor that is afforded by a wider road tire is the increase in traction, which allows more confident handling while allowing riders to really take advantage of the increased stopping power of disc brakes.
As with all of ENVE's SES rims, the front and back rims feature different profiles, optimized to tackle the different wind resistances between the front and rear of the bike. The front rim is .5mm wider and 6mm more shallow improving handling and cutting wind more efficiently. The rear rim, with it's slightly more narrow profile and 55mm depth, decreases pressure drag and smooths out air coming off of the trailing edge.
Shipping ENVE Internationally
Wheel Building
We recommend that wheels built with Enve 4.5 AR rims be assembled by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in hub and spoke selections. Please contact us directly.
ENVE Rim Comparison
The following table compares ENVE's disc brake models for a quick and easy analysis. For more information follow the link to our product specific page for the rim or Contact Us to get in touch with one of our professional wheel-builders.
Model | Depth (mm) Front/Rear | Width (mm) External | Width (mm) Internal | Weight (g) Front/Rear |
New 3.4 Disc Clincher | 38 / 42 | 27.5 / 27.5 | 21.0 / 21.0 | 390 / 397 |
4.5 AR Disc Tubeless | 49 / 55 | 31 / 30.5 | 25 / 25 | 440 / 450 |
4.5 AR Disc Tubular | 49 / 55 | 31 / 30.5 | N/A | 388 / 396 |
5.6 Disc Clincher Tubeless | 54 / 63 | 28.75 / 28 | 19 / 19 | 450 / 470 |
5.6 Disc Clincher Tubular | 54 / 63 | 28.75 / 28 | N/A | 384 / 406 |
Weight (front/rear) | 440 / 450 grams |
External Width (front/rear) | 31.0 / 30.5 mm |
Internal Width (front/rear) | 25.0 / 25.0 mm |
Depth (front/rear) | 49 / 55 mm |
ERD (front/rear) | 558 / 547 mm |
Tire Compatibility | ISO 622 road tubeless |
Recommended Tire Width | 28 mm |
Material | carbon fiber |
Finish | UD Matte |
Brake Compatibility | disc brake only |
Included Accessories | Enve 4.5 Road Tubeless Kit Enve 45mm Silca Valve Extenders (non-tubeless) Enve Brass Internal Spoke Nipples |
