ENVE SES 3.4 Carbon Clincher Tubeless Rim
$2,190.00
ENVE's SES 3.4 Rim sets the standard for versatility and performance. With Wide Hookless Bead technology and a high-volume design, it offers exceptional pinch-flat resistance, low weight, and optimized aerodynamics for high-volume tires. Ideal for both road racing and mixed-surface events, it's the ultimate all-around rim choice.
Trust experienced wheel builders for top-notch assembly of ENVE rims. Opt for our expert wheel-building service and receive valuable advice on hub and spoke selection. Contact us for personalized assistance.
 Model SES 3.4 Legacy 3.4 Disc Legacy 3.4 AR
  Front Rear Front Rear Front Rear
 Rim Depth 39 mm 43 mm 38 mm 42 mm 39 mm 43 mm
 External Width 32 mm 27.5 mm 32 mm
 Internal Width 25 mm 21 mm 25 mm
 Weight ~370g ~378g ~390g ~397g ~387g ~394g
SES 3.4 Specifications Front Rear
ERD 578 591
Hole Count 24 hole
Bead Type Hookless
Tire Type Tubeless Ready
Minimum Tire Size 700 x 27
Valve Stem Length* 59 mm 61 mm
Tubeless Tape Width* 29 mm
TIRE COMPATIBILITY
INCLUDED
Tubeless Kit - Tape / Valves (SES 3.4 (AR))*
Brass Nipples
Valve Extenders (55 mm)
