As a manufacturer dedicated to keeping up with an ever-evolving industry, Enve has produced an updated version of their 3.4 road disc rim set. This latest iteration includes full compatibility with road tubeless tires, optimization for 25mm wide tires, and an updated SES aerodynamic profile. Relative to the original 3.4 rim design, the New 3.4 features a decreased depth ratio of 90% between front and rear rims, with a wider rear rim to match the width of the front rim. The advantages of this new design include lower overall weight and lower tire rolling resistance, with increased stability and traction.
Enve's 3.4 platform provides lightweight rims with an aerodynamic advantage - an excellent option for riders who thrive when the roads point upward, but desire wheels that are fast in a variety of conditions and terrain. These road disc specific rims are designed with modern road disc frames in mind, taking advantage of increased frame clearance for wider tires. The increased traction from wider 25 or 28c tires allows the rider to really take advantage of the increased stopping power of disc brakes.
Enve's line of carbon rims are all covered under their industry-leading five year manufacturer's warranty, as well as a lifetime loyalty guarantee. See details here.
The following table compares ENVE's disc brake models for a quick and easy analysis. For more information follow the link to our product specific page for the rim or Contact Us to get in touch with one of our professional wheel-builders.
Model | Depth (mm) Front/Rear | Width (mm) External | Width (mm) Internal | Weight (g) Front/Rear |
3.4 Disc Clincher | 38 / 42 | 27.5 / 27.5 | 21 / 21 | 390 / 397 |
4.5 AR Disc Tubeless | 49 / 55 | 31 / 30.5 | 25 / 25 | 440 / 450 |
4.5 AR Disc Tubular | 49 / 55 | 31 / 30.5 | N/A | 388 / 396 |
5.6 Disc Clincher Tubeless | 54 / 63 | 28.75 / 28 | 19 / 19 | 450 / 470 |
5.6 Disc Tubular | 54 / 63 | 28.75 / 28 | N/A | 384 / 406 |
Weight (front/rear) | 390/397 grams |
External Width (front/rear) | 27.5/27.5 mm |
Internal Width (front/rear) | 21/21 mm |
Depth (front/rear) | 38/42 mm |
ERD (front/rear) | 580/573 mm |
Tire Compatibility | ISO 622 clincher road tubeless |
Recommended Tire Width | 25 mm |
Material | carbon fiber |
Finish | unidirectional carbon |
Brake Compatibility | disc brake only |
Included Accessories | Enve 3.4 Road Tubeless Kit Enve Rim Strips (non-tubeless) Enve 34mm Silca Valve Extenders (non-tubeless) Enve Brass Internal Spoke Nipples |
