ENVE PRV Replacement Tubeless Valve Stems
Article number: | 013-02-07 |
ENVE's tubeless valve stem is a precision-machined component designed for reliable tubeless tire setup and durability. Made from lightweight 7075 aluminum, each stem includes a removable valve core for easy sealant injection and a pressure relief valve nut to prevent air loss. The valve core remover doubles as a valve cap for a clean look.
Available in multiple lengths to fit various rim depths, these stems ensure an airtight interface for smooth rolling. ENVE's attention to detail guarantees hassle-free tubeless performance for riders seeking lower tire pressures.
For assistance, contact us.
Length* | Max Rim Depth | Compatible |
35 mm | 25 mm | M525 / M5 Pro / M6 / AM30 / AG25 / AG28 |
47 mm | 35 mm | SES 2.3 / G-Series / M-Series |
59 mm | 49 mm | Foundation 45 / SES 3.4 Front |
61 mm | 51 mm | SES 3.4 Rear |
66 mm | 56 mm | M685 / SES 4.5 Front |
72 mm | 62 mm | SES 4.5 Rear |
80 mm | 70 mm | Foundation 65 / SES 6.7 Front |
85 mm | 75 mm | SES 6.7 Rear / 7.8 Front |
95 mm | 85 mm | 7.8 Rear |
* All Valves come with an ENVE Valve Core Remover and PRV Nut |
