ENVE PRV Replacement Tubeless Valve Stems
$10.50
ENVE's tubeless valve stem is a precision-machined component designed for reliable tubeless tire setup and durability. Made from lightweight 7075 aluminum, each stem includes a removable valve core for easy sealant injection and a pressure relief valve nut to prevent air loss. The valve core remover doubles as a valve cap for a clean look.
Available in multiple lengths to fit various rim depths, these stems ensure an airtight interface for smooth rolling. ENVE's attention to detail guarantees hassle-free tubeless performance for riders seeking lower tire pressures.
For assistance, contact us.
Length* Max Rim Depth Compatible
35 mm 25 mm M525 / M5 Pro / M6 / AM30 / AG25 / AG28
47 mm 35 mm SES 2.3 / G-Series / M-Series
59 mm 49 mm Foundation 45 / SES 3.4 Front
61 mm 51 mm SES 3.4 Rear
66 mm 56 mm M685 / SES 4.5 Front
72 mm 62 mm SES 4.5 Rear
80 mm 70 mm Foundation 65 / SES 6.7 Front
85 mm 75 mm SES 6.7 Rear / 7.8 Front
95 mm 85 mm 7.8 Rear
* All Valves come with an ENVE Valve Core Remover and PRV Nut
