Enve M525 Carbon Mountain Rim
$999.00
The latest generation of Enve's M-Series carbon mountain rims address a critical concern of riders: the possibility of expensive damage from the heavy impacts that inevitably occur when riding off road. The rims across this new series feature wide hookless tire beads to increase the load area from impacts, significantly reducing the possibility of pinching a tubeless tire or cracking a rim. Enve's confidence in their design is apparent in their industry-leading 5 year "no hassle" warranty policy that explicitly covers damage from impacts. This system allows riders to roll with confidence and choose lighter, faster tires for improved speed and performance.
The M525 rim is Enve's flagship XC racing rim, lightweight and nimble for maximum speed on cross country style courses, yet strong enough for daily riding. Relative to the other M-Series rims, the 525 is shallow for increased compliance and reduced weight, with a 25mm internal bead width optimized for 2.1-2.3" wide tires. As with every rim Enve has ever built, these rims are designed for internal nipples with spoke holes that are molded and not drilled for the best possible strength and long-term durability. Enve's corrosion-resistant self-locking brass nipples are included. The rim bead features an ultra-reliable tubeless ready design, and each rim purchase includes a full tubeless kit with tape and valves. M525 rims are available in 24 hole only for the lightest possible complete wheels.
Warranty
Enve M-Series rims are guaranteed to be free from defects in materials or workmanship for five years from the original purchase date. Rest assured that Enve will cover impact damage from riding.
Weight, 27.5" 349 grams
Weight, 29"367 grams
External Width33.5 mm
Internal Width25.0 mm
Depth25.0 mm
ERD 27.5"569 mm
ERD 29"608 mm
Tire Compatibility, 27.5"ISO 584 mm, tubeless
Tire Compatibility, 29"ISO 622 mm, tubeless
Recommended Tire Width2.1-2.4" / 32c and Larger
Materialcarbon fiber
FinishUD matte
Included AccessoriesEnve tubeless kit, Enve internal brass spoke nipples
Tubeless Rims
UD Matte
Size:
27.5"
Size:
29"
Fits:
24h
Style:
Mountain
Carbon
