Building on the success of their original road stem computer mount, ENVE has teamed up with K-Edge to introduce the newest iteration of their sleek, integrated stem mount. Expertly machined in the US by K-Edge, Enve’e new Road Stem Computer Mount doubles the functionality of the original with an underside mount for action cameras or lights. These mounts, manufactured from 6061 T6 aluminum, feature interchangeable inserts that allow usage with a multitude of computers, cameras, and lights. Included are inserts for Garmin computers, Wahoo computers, as well as an underside Go-Pro style mount for action cameras or lights (the underside insert can also be removed altogether). This mount installs onto ENVE road stems using the included longer stem bolts providing a seamless aesthetic by perfectly with the contours of the stem’s faceplate. Finished handsomely in black, each mount weighs 60 grams (including hardware) and features small, subtle ENVE and K-Edge logos in white. All mounting hardware as well as inserts for Garmin computers, Wahoo computers, and an underside Go-Pro style mount for action cameras or lights are included (the underside insert can also be removed altogether).
We still have a few of the original Enve Road Stem Computer mounts available. These mounts are similar to the new combo mounts in aesthetics and integration, however can only accommodate a Garmin computer and feature no lower mounting options for lights or cameras. These single mounts weigh 37 grams with included mounting hardware (ie longer stem bolts).
ENVE Combo Mount | |
Weight | 60 grams (including stem bolts/mounting hardware) |
Material | 6061 T6 aluminum plastic |
Computer Compatibility | Garmin Edge / Forerunner type mounts (1030, 1000, 820, 520, 510, 500, 25, 20, etc), Wahoo |
Camera / Light Compatibility | Go-Pro style action cameras and lights |
Stem Compatibility | ENVE Road Stem |
Enve Single Mount | |
Weight | 37 grams (including stem bolts/mounting hardware) |
Material | aluminum plastic |
Computer Compatibility | Garmin Edge / Forerunner type mounts |
