ENVE G27 650b Gravel Rim
Article number: | 15-01-03 |
The versatile ENVE G27 gravel rim expands possibilities for drop bar adventures, clearing tires from 42 mm gravel to 2.25” MTB tires for confident riding on rugged singletrack. ENVE's patented Wide Hookless Bead rim design dramatically reduces pinch flats when running low tire pressures off-road. Durable yet lightweight at 320g, the tubeless-ready G27 maintains secure tire seal thanks to the molded bead lock, enabling true mixed-surface riding.
Select our premium wheel-building service for the precise assembly of ENVE rims. Gain valuable recommendations on hub and spoke selection. Reach out to us for personalized support.
DIMENSION | |
Weight | ~320g |
Rim Depth | 25 mm |
Hole Count | 24 Hole |
Bead Type | Hookless |
Tire Type | Tubeless Ready |
Suitable Tire Widths | 650b x 42 - 57 mm | 27.5 x 1.65" - 2.25" |
INCLUDED - G27 Tubeless Kit | |
30.5 mm Tubeless Tape | |
47 mm Tubeless Valves | |
Brass Nipples |
_____________________________: | ________________________ |
External Width: | • 35.5 mm |
Internal Width: | • 27 mm |
ERD: | • 571 mm |
Material: | • Carbon Fiber |
Finish: | • UD Satin |
Brake Compatibility: | • Disc Brake Only |
Recommended Tire Width: | • 650b x 42 - 57 mm | 27.5 x 1.65" - 2.25" |
