Enve's standard carbon road handlebar is equipped with thoughtful design features, resulting in an elegant, functionally superior cockpit piece. Compared to its compact cousin, the standard bar has a 6 mm longer reach and a 17 mm deeper drop. The standard geometry of this road handlebar is favored by racers and traditionalists, as well as flexible riders who enjoy more varied options in hand position.
Enve's road handlebar design focuses on strength and comfort rather than absolute ultralight weight, and is equipped with several innovative features. The bar is double grooved on the underside for easy cable routing, and features a semi-flat hand section on top with a subtle ergo bend. Additionally, Enve makes use of textured non-slip sections at the stem and lever mounting positions for maximum security. This bar also features Enve's signature integrated rubber bar end plugs that replace the typical cheap plastic plugs to prevent bar tape from unraveling.
All Enve handlebars are clip on compatible as long as all clamping is done within the 105mm wide clamp area. Make sure that the outer edge of your clip on aero bar is no more than 52.5mm from center.
Drop | 144 mm |
Reach | 85 mm |
Stem Clamp | 31.8 mm |
Clamp Area Width | 105mm |
Weight | |
40cm | 198 grams |
42cm | 203 grams |
44cm | 208 grams |
