ENVE Carbon Road Stem
Article number: | 013-01-02 |
ENVE's Carbon Road Stem, crafted with precision from Unidirectional carbon weave and adorned with subtle gloss black decals, signifies the epitome of performance and aesthetics. The cold-forged faceplate and titanium hardware not only contribute to weight savings but also ensure maximum rigidity. While lighter options exist, the ENVE Carbon Road Stem uniquely marries strength, beauty, and function, setting a new standard in cycling components.
INSTALLING
A torque wrench is highly recommended when installing any ENVE stem. Each bolt's max torque is 5.5 Nm. Park Tool SuperGrip aids assembly, reducing required bolt torque.
80 mm | 90 mm | 100 mm | 110 mm | 120 mm | 130 mm | 140 mm | |
Weight | ~118g | ~122g | ~124g | ~129g | ~133g | ~137g | ~142g |
Stack Height | 41 mm | ||||||
Rise | ± 6° | ||||||
Torque | 5.5Nm |
