$400.00
$320.00
* Unit price: $320.00 /
Article number: 19-02-00
COMPACT HANDLEBAR
Innovative features like cable routing grooves, a semi-flat hand section, and ergonomic bend make the Compact Handlebar a top choice while blending strength, comfort, and low weight. The latest version includes drill-holes for Di2 wire routing and Shimano A-Junction. Install the bar-end Di2 junction box by removing integrated bar plugs and following cut lines for a straightforward setup.
STANDARD HANDLEBAR
The Standard Road Handlebar by ENVE offers outstanding strength and comfort. Featuring double cable routing grooves and a textured, non-slip design, it ensures a secure grip. Integrated rubber bar end plugs and clip-on compatibility enhance its functionality. Experience an upgrade in your cycling with this premium handlebar option.
 Width C(enter) - C(enter) Compact Standard
 Hoods 38 / 40 / 42 / 44 / 46 cm 40 / 42 / 44 cm
 Dropouts 40 / 42 / 44 / 46 / 48 cm 42 / 44 / 46 cm
 Reach 79 mm 85 mm
 Drop 127 mm 144 mm
 Weight ~212g - ~230g ~198g - ~214g
 Di2 Compatible Yes No
 Stem Clamp Diameter 31.8 mm
  5.5Nm 6 - 8Nm
