ENVE Carbon Road Handlebar
Article number: | 19-02-00 |
COMPACT HANDLEBAR
Innovative features like cable routing grooves, a semi-flat hand section, and ergonomic bend make the Compact Handlebar a top choice while blending strength, comfort, and low weight. The latest version includes drill-holes for Di2 wire routing and Shimano A-Junction. Install the bar-end Di2 junction box by removing integrated bar plugs and following cut lines for a straightforward setup.
STANDARD HANDLEBAR
The Standard Road Handlebar by ENVE offers outstanding strength and comfort. Featuring double cable routing grooves and a textured, non-slip design, it ensures a secure grip. Integrated rubber bar end plugs and clip-on compatibility enhance its functionality. Experience an upgrade in your cycling with this premium handlebar option.
Width C(enter) - C(enter) | Compact | Standard |
Hoods | 38 / 40 / 42 / 44 / 46 cm | 40 / 42 / 44 cm |
Dropouts | 40 / 42 / 44 / 46 / 48 cm | 42 / 44 / 46 cm |
Reach | 79 mm | 85 mm |
Drop | 127 mm | 144 mm |
Weight | ~212g - ~230g | ~198g - ~214g |
Di2 Compatible | Yes | No |
Stem Clamp Diameter | 31.8 mm | |
Torque Specs | Faceplate | Shift / Brake Clamp |
5.5Nm | 6 - 8Nm |
