ENVE Road Disc Brake Fork
$575.00
Article number: 013-06-00
ENVE's Road Disc Fork evolves from their renowned road fork, seamlessly adapting to modern preferences with disc brakes and larger tires. Crafted with one-piece construction to handle disc brake forces and rough terrain, it features a 12 x 100mm road thru axle, disc brake mounts, clearance for 32mm tires, and a tapered 1-1⁄8” to 1-¼” steerer tube. The subtle design incorporates black logos and internal brake hose routing, marrying modern aesthetics with technical prowess.
INSTALLATION
Expertise and specialized tools are essential for accurate sizing and installation of a carbon fork. We strongly advise relying on an experienced mechanic for these services.
 Rake 43 mm 50 mm
 Axle to Crown 370 mm
 Steerer Tube Length 350 mm
 Steerer Tube Diameter 1-1⁄8 " (1.125")
 Crown Race Diameter 1-¼" (1.5")
 Brake Compatibility Disc Only
 Brake Mount Flat Mount
 Weight ~425g
 Rotor Compatibility 140 mm / 160 mm
 Axle Compatibility 12 x 100 mm
 Includes Expander Plug and Carbon Top Cap
 Max Tire Clearance 700 x 32 mm
 Torque Specs Steerer Tube Axle
  5.5Nm 8Nm
