ENVE Road Disc Brake Fork
Article number: | 013-06-00 |
ENVE's Road Disc Fork evolves from their renowned road fork, seamlessly adapting to modern preferences with disc brakes and larger tires. Crafted with one-piece construction to handle disc brake forces and rough terrain, it features a 12 x 100mm road thru axle, disc brake mounts, clearance for 32mm tires, and a tapered 1-1⁄8” to 1-¼” steerer tube. The subtle design incorporates black logos and internal brake hose routing, marrying modern aesthetics with technical prowess.
INSTALLATION
Expertise and specialized tools are essential for accurate sizing and installation of a carbon fork. We strongly advise relying on an experienced mechanic for these services.
Rake | 43 mm | 50 mm |
Axle to Crown | 370 mm | |
Steerer Tube Length | 350 mm | |
Steerer Tube Diameter | 1-1⁄8 " (1.125") | |
Crown Race Diameter | 1-¼" (1.5") | |
Brake Compatibility | Disc Only | |
Brake Mount | Flat Mount | |
Weight | ~425g | |
Rotor Compatibility | 140 mm / 160 mm | |
Axle Compatibility | 12 x 100 mm | |
Includes | Expander Plug and Carbon Top Cap | |
Max Tire Clearance | 700 x 32 mm | |
Torque Specs | Steerer Tube | Axle |
5.5Nm | 8Nm |
