For the purists who like to keep their mountain bikes simple, Enve presents an elegant and lightweight front end option with their rigid carbon fiber mountain fork. With just one available configuration, this full carbon fork conforms to the most popular modern standards: 29" diameter wheel, tapered 1-1/8"-1-1/2" steerer, post mount disc brake, and a 15mm thru axle. On top of these basic specs, Enve includes quite a few innovations to set their fork apart from other manufacturers' options. Offset reversible dropout inserts allow the rake to be changed between 44 and 52mm, accommodating most frame geometries while adding the possibility to tune the handling characteristics of the bike. As with their other disc forks, Enve includes a simple carbon clip to secure the brake hose, negating the need for zip ties for a much cleaner look. As a finishing touch, Enve includes a removable mini fender to help keep water and mud off the frame and rider.
Please note that this fork has a 1.5 inch tapered steerer tube, and thus is only compatible with frames accepting the format.
Due to the specific tools required, we recommend that Enve forks be installed by a professional mechanic.
Weight, with Fender | 711 grams |
Weight, with Clasps | 686 grams |
Material | carbon fiber |
Axle to Crown, 44 rake | 470 mm |
Axle to Crown, 52 rake | 474 mm |
Steerer | 1.125" - 1.5" tapered |
Rotor Size | 160 / 180 mm |
Wheel Size | 29er |
Max Tire Size | 88 mm (3.46") |
Axle | ENVE 15 mm thru |
