ENVE AG25 Foundation Wheelset
Article number: | Wheels / Rims |
ENVE's AG25 gravel wheelset excels off-road with a wide hookless bead, tuned carbon, external nipples, and the Foundation Road Hub, offering a value-packed gravel solution. The rim features an anti-pinch flat profile and external molded spoke holes for enhanced strength and serviceability. With a 25mm internal width, these rims optimize larger gravel tires, combining stiffness with compliance for rough terrains. ENVE's road hubs ensure maximum wheel stiffness with a 40-tooth ratchet for quick engagement and low drag. Whether gravel racing or bikepacking, ENVE's AG25 Wheelset delivers high-performance for mixed terrain adventures.
AG25 | ||||
Weight | ~1480g | |||
Tubeless Tape Width* | 29 mm | |||
Valve Stem Length* | 35 mm | |||
Bead Type | Hookless | |||
Minimum Tire Width | 700 x 32 mm | |||
INCLUDES | ||||
Tubeless Kit* | AG25 | |||
Brass Nipples | ||||
ENVE Tire Compatibility |
