ENVE In-Route Aero Carbon Handlebar
$400.00
Article number: 013-05-00
Availability: In stock (1)
The aerodynamically optimized Aero In-Route carbon road bar allows you to reduce drag and go faster. Through careful shaping and minimizing frontal surface area, it's the ideal bar for road cyclists and triathletes seeking maximum aero benefits. ENVE's unique compact geometry offers thoughtful ergonomics while remaining compatible with both analog and electric drivetrains. The updated IN-Route design ensures compatibility with most internally routed front ends. Made from lightweight yet durable carbon fiber, the SES Aero Handlebar features integrated bar end plugs and is available in multiple widths to dial in your ideal fit. Designed for use with the In-Route Aero Stem for clean aesthetics and airflow.
Depending on your riding style, it may be advisable to select a wider handlebar than you would normally ride.
 Width C(enter) - C(enter) 40 cm 42 cm 44 cm 46 cm
 Hoods 35 cm 37 cm 39 cm 41 cm
 Drops 40 cm 42 cm 44 cm 46 cm
 Weight ~266g ~270g ~280g ~290g
 Reach 79 mm
 Drop 127 mm
 Internal Di2 Routing Yes
 Clamp Diameter 31.8 mm
 Material Carbon
 Clamp Area 48 mm
  5.5Nm 6 - 8Nm
