ENVE SES 2.3 Carbon Clincher Tubeless Rim
$2,190.00
Article number: 15-04-01
ENVE's SES 2.3 Wheelset is meticulously crafted for superior road performance. Featuring an ultra-lightweight design, aerodynamic optimization, and tubeless compatibility, it delivers unparalleled speed and efficiency. With front depth at 28mm and rear depth at 32mm, this wheelset ensures stability in crosswinds and maximum speed on flat terrain. The use of hookless bead tubeless technology guarantees precise tubeless setup and enhanced strength. Designed exclusively for disc brakes, it's the ultimate choice for road cyclists seeking peak performance. ENVE's SES 2.3 Rims, designed for high-speed road performance, are crafted with an extremely lightweight construction, making it unsuitable for off-road or gravel applications.
Opt for our expert wheel-building service for top-notch rim assembly. We offer valuable advice on hub and spoke selection. Contact us for personalized assistance.
 SES 2.3
  Front Rear
 Rim Depth 28 mm 32 mm
 ERD 604 599
 External Width 25 mm
 Internal Width 21 mm
 Weight ~275g ~280g
 SES 2.3 Specifications Front Rear
 Hole Count 24 hole
 Bead Type Hookless
 Tire Type Tubeless Ready
 Minimum Tire Size 700 x 25
 Valve Stem Length* 47 mm
 Tubeless Tape Width* 25 mm
TIRE COMPATIBILITY
INCLUDED
Tubeless Kit - Tape / Valves (2.2 / 2.3)*
Brass Nipples
Valve Extenders (39 mm)
