EliLee X310 Crank
$380.00
Article number: 002-03-01
The Elilee X310 has been redesigned and improved. At 310 grams these cranks are not only lighter, but also stiffer than the previous model. Additionally the adapters required on the previous generation crank(X320) are no longer needed, reducing the probability of crank spindle noise occurrence. Just like the other cranks in their line, the X310 cranks are direct mount, allowing you to choose between a standard 4 or 5 bolt spider, a spider based power meter, or a direct mount chainring.  The X310 is available in all of the most common crank arm lengths.
Spiders are available in both aluminum and carbon options. Check them out here.
If there is a length you would like that is not listed as available, or if you have questions about power meter spider options, then contact us, and we will be happy to help you.
 Crankarms 162.5 / 165 / 167.5 / 170 / 172.5 / 175
 Weight 308g(172.5)
 Q-Factor 149
 Chainline 44.5
 Bottom Bracket DUB
 Interface/BCD Direct Mount Spider(CINCH)/Chairing
 Spindle DUB Aluminum
