Easton R90 SL, DT Swiss Disc Brake Wheelset
$1,249.00 $962.60
(You save $286.40)
When we worked on spec'ing our rim brake version of the Easton R90 SL, DT Swiss 240s Wheelset we figured, given our intial goal, it would be inexplicable to not offer a disc brake version of our workhorse wheelset. Or, in other words, a wheelset meant to be ridden in a variety of conditions, over long miles with emphasis placed on dependability and serviceability needs the option of running full disc brakes which will perform better in mud and wet than rim brakes ever could.
As custom wheel builders, spec’ing a wheelset to fit this workhorse definition is something we take a lot of pride in. Our first consideration is context: Are the wheels’ components able to handle a wide variety of situations and terrain riders may find themselves in? For a 700c clincher wheelset, this would include (at a minimum) cyclocross, gravel, road training and even a bit of racing. Secondly, we consider long-term durability. Not only should the wheelset perform well in these situations, it should be able to do so with minimal maintenance and long service intervals. Finally, when service does become necessary, it should be a simple task when entrusted with a competent mechanic.
We feel by picking Easton’s R90 SL disc rim we’ve addressed all these issues. The 25mm (19.5mm internal) wide rim is perfect for tires into the Cyclocross / Gravel grinder widths. The slightly deeper than the Belgium C2+ will be welcomed on flats and fast roads and the manufacturing quality means you’ll be riding it for years.
For hubs, the DT Swiss’ tried-and-true 240s hubset bring simplicity, longevity, and ease of service. Sometimes when you're looking at a workhorse you want your most complex component to be serviceable by any shop. You want parts that are easy to replace and source. With this in mind the DT-Swiss is our hub of choice.
Spokes are often the unsung heroes of any wheel build, and like all unsung heroes are often only discussed when something is going wrong. With this in mind we picked the Sapim CX-ray spoke. If you’ve talked to us about custom wheels or noticed our wheels before, chances are you’ve seen that we’re a fan of the CX-Ray for the simple reason, that it’s a workhorse spoke.
Custom Wheels
If you're looking for a custom version of this wheelset or want to discuss if this is the right set of wheels for you we are happy to talk. Please contact us directly (Phone: (520) 624-3045, Email: feedback@fairwheelbikes.com) or contact us via email on this form.
Weight 1534g
Tire Compatibility Tubeless
Rim Width (Outer / Inner) 24mm / 19.5mm
Front Axle Compatibility Quick Release, 12mm, 15mm
Rear Axle Compatibility Quick Release, 12 x 142mm
