Easton R90 SL Disc Clincher Rim
$128.00
Known by many discerning cyclists for their high level of engineering prowess, Easton has been a main staple in the cycling world for quite some time. With a vast array of quality parts designed to take your build to the next level, Easton has created a hard-earned reputation as an elite level manufacturer.
Arguably one of the finest choices for road disc, cyclocross, and gravel builds to date, the R90 SL Disc rim from Easton is an incredibly versatile option that’s ready to tackle any terrain you throw its way. Featuring a 24mm outside diameter and a widened 19.5mm inside diameter, the R90 SL has the ability to accommodate tire sizes ranging from road to cyclocross standards, making it perfect for a variety of performance-driven wheel builds. Additionally, utilizing a 27mm deep cross-section, the R90 SL Disc offers each rider the aerodynamic benefits of wider and deeper rims, while simultaneously shaving grams to keep overall wheel build weight to a minimum. Each R90 SL rim is tubeless compatible when equipped with tubeless valves and rim tape.
Weight449 grams
MaterialAluminum
Outer Width24mm
Inner Width19.5mm
Depth27mm
Tubeless CompatibleYes
ERD585
Clincher Rims
Size:
700c
Fits:
28h
Style:
Road Disc
Aluminum
