Easton EC70 Zero Seatpost
$128.00
With an impressive repertoire of components and upgrades for a variety of disciplines, Easton is one of the leading manufacturers of performance tuned cycling equipment.
Based on the same features seen on the EC90 seatpost, the EC70 differs only in the use of an aluminum upper clamp. Created with Monocoque carbon construction, the EC70 is equipped with Easton’s proprietary Relief-Area Design™ and TaperWall™ technology, granting it both low weight and impressive performance characteristics. Additionally, these technologies distribute stress and road vibrations throughout the entire length of the post evenly, resulting in enhanced ride quality and durability. The aluminum cradle has been designed to allow micro-adjustments to both saddle angle and fore / aft positions, making dialing in your ideal fit as easy as possible.
Weight215 grams (31.6mm)
MaterialCarbon
Setback0mm
Length300mm
350mm
Diameter27.2mm
31.6mm
Straight Post
UD Matte
Size:
300mm
Size:
350mm
Diameter:
27.2mm
Diameter:
31.6mm
Carbon
