The Strada Silk tubualr tire is Dugast's high-end version of its workhorse Strada Cotton tire. The silk casing provides a more supple ride versus the cotton version. This is important to rolling resistance, feel, and handling of the tire. Other than that, the Strada Silk uses the same all weather tread pattern designed for handling in conditions varying from northern windswept classics to the winding descents of the grand tours. If you've ever wondered what profesional riders would choose, look no further than this tire. Dugast is popular for being a staple of the pro peleton, especially in the northern classics where tire performance is all the more important.
This history is goes back decades to when Dugast was a low-production tire company selling handmade tubulars almost exclusively for professional riders and leaving a small amount for purchase at boutique shops. This changed around 2003 when, under new leadership, the brand expanded to provide higher volumes to increasing demand. Still noted for their quality, the brand has not suffered from the growth and a Dugast tire is still where discerning riders choose to spend their money.
If you're looking for a trainer tire to go on your spare wheelset a Strada Cotton tire might fit your requirements at a slightly lower price. If you're looking to tackle a wider range of surfaces and conditions look no further than the Paris Roubaix Cotton Tubular from Dugast. It's where most performance oriented riders end their search when looking to tackle the famed cobbles of the north.
With all tubular tires we'd recommend having an experienced shop mount your tires for you. If you feel confident, have done this before, or have a friend to help out here's the instructions Dugast recommends for their tire installs. I've edited the original instructions to make a bit more sense to an English reader and added a few notes of my own. As with all install instructions, but especially gluing tubulars, we are not responsible for any injuries or mishaps if you're following these instructions.
Again, we can't stress enough that this is more likely to be done correctly by an experienced mechanic. Rolling a tire is a painful, and potentially costly way to realize you did something wrong. Also, there many methods for gluing tires, opinions on tape versus glue, and the best way to glue; we're just trying to help you make sense of the English translation on the Dugast website.
Weight, 23mm | 310g* |
Weight, 25mm | 355g* |
Weight, 27mm | 350g* |
Rim Compatibility | 28" (road) tubular |
Casing Material | Silk |
Tube Material | Butyl |
