DT Swiss Rear Axle Adapter
$47.70
Article number: 019-04-03
Replacement EXP freehubs, will not work on older DT Ratchet sytle hubs.
All freehub kits include a drive / right side end cap, they don't include both. If you need to change your hub to a different axle adapter, please order the freehub without the end cap. You can find the correct kit here.
Campagnolo 9-12 Speed Campy N3W
 HWYABL00S7073S 5 mm QR  HWYABL00S2993S Thru Axle Kit
 HWYABL00S7074S Thru Axle Kit  HWRABL00S2321S w/o End Caps
 HWRABL00S4864S w/o End Caps
Shimano Micro Spline Shimano Mountain 10 Speed
 HWYABL00S5374S Thru Axle Kit  HWYABL00S5370S Thru Axle Kit
 HWRABL00S4863S w/o End Caps  HWRABL00S3123S w/o End Caps
Shimano Road 11 Speed
 HWYABL00S5399S 5 mm QR
 HWYABL00S5378S Thru Axle Kit
 HWRABL00S4866S w/o End Caps
SRAM XD SRAM XDR
 HWYABL00S5372S Thru Axle Kit  HWYABL00S5382S 5 mm QR
 HWRABL00S3830S w/o End Caps  HWYABL00S5401S Thru Axle Kit
     HWRABL00S4865S w/o End Caps
