DT Swiss 350 Straight-Pull Disc Rear Hub
Article number: | 024-03-03 |
The updated DT Swiss 350 hub is lighter, thanks to a redesigned shell, axle, and Ratchet SL freehub. Reliability and simplicity are its core, making maintenance easy. It inherits DT 240 features at a budget-friendly price, with standard bearings and spoke pattern for easy servicing. Opt for the 54-tooth ratchet for quick engagement or the Rapid Drive rings for a performance boost.
WHEEL BUILDING
Trust a skilled wheelbuilder for DT Swiss hub wheels. Please contact us for expert service and rim/spoke advice.
Application | Road | MTB | ||||
Weight | ~219g | ~233g | ||||
Spoke Holes | 24 | 28 | ||||
Bearing Size | 6902 - (2) | |||||
Axle Standard | 12 x 142 mm | |||||
Brake Interface | Centerlock | |||||
Freehub Body Options | Shimano 11 / SRAM XDR | Shimano 10 / SRAM XD | ||||
Freehub System | 36t SL Ratchet | |||||
--Wheel Building Dimensions-- | ||||||
Flange Diameter Left | 38.7 mm | 39 mm | ||||
Flange Diameter Right | 46.2 mm | 48.7 mm | ||||
Center to Left Flange | 34.2 mm | 35.8 mm | ||||
Center to Right Flange | 17.6 mm | 18.4 mm | ||||
Spoke Hole Offset L / R | 1.4 / 0.4 | 1.9 / 0.2 | ||||
Spoke Hole Diameter | 2.5 mm |
