DT Swiss 350 Straight-Pull Disc Front Hub
Article number: | 024-01-04 |
The updated 350 hub is lighter with a redesigned shell, axle, and Ratchet SL freehub, embodying reliability and simplicity. It inherits DT 240 features at a budget-friendly price, thanks to refined manufacturing. With standard bearings and a typical spoke pattern, these hubs are easily serviced. DT Swiss 350 hubs are a durable, high-performance investment.
WHEEL BUILDING
T/A 12 | 15 mm C/L | 15 mm 6-Bolt | |
Weight | ~132g | ~129g | ~137g |
Bearing Size | 6902 - (2) | ||
Spoke Holes | 24 | 28 | |
Axle Standard | 12 x 100 mm | 15 x 100 mm | |
--Wheel Building Dimensions-- | |||
Flange Diameter Left | 38.4 mm | 40.8 mm | 40.8 mm |
Flange Diameter Right | 37.6 mm | 36 mm | 36 mm |
Center to Left Flange | 22.1 mm | 23 mm | 23 mm |
Center to Right Flange | 35.1 mm | 35 mm | 35.2 mm |
Spoke Hole Diameter | 2.5 mm | 2.5 mm | 2.5 mm |
Spoke Hole Offset L / R | 1.4 / 1.8 | 1.7 / 1.8 |
