(P22) DT Swiss 350 Straight-Pull Disc Front Hub
$76.90
$61.50
* Unit price: $61.50 /
Article number: 019-04-05
Availability: In stock (3)
Discover the perfect fusion of reliability and simplicity with the DT Swiss 350 hub. Engineered for optimal function, its plug-and-play design allows tool-free maintenance, making it a smart choice for cyclists. These hubs bring the key features of the famous DT 240 line to a more affordable price point, making premium performance accessible to budget-conscious riders. With common-sized sealed cartridge bearings and a standard spoke hole drilling pattern, they can be serviced easily by bike shops or home mechanics. Whether you need season-long gear durability or peak equipment performance, DT Swiss 350 hubs are a solid investment.
DT hubs come with a 2-year warranty against defects, providing top-notch quality at a reasonable price. Experience the best of both worlds with DT Swiss 350 hubs.
WHEEL BUILDING
  24 hole 28 hole
 Weight ~134g ~130g
 Axle Standard TA 12 x 100
 Bearings Size 6902 - (2)
 Brake Interface Disc Brake
 Flange Diameter Left 39 mm 38.5 mm
 Flange Diameter Right 37.5 mm 36.5 mm
 Center to Left Flange 21.3 mm 21.4 mm
 Center to Right Flange 34.9 mm 35.1 mm
 Spoke Hole Diameter 2.5 mm
 Spoke Hole Offset L / R 2.5 / 2.1 mm 1.0 / 0.95 mm
