DT Swiss 350 Straight Pull Centerlock Front Hub
$88.70
DT Swiss' 350 series hubs offer exceptional performance and durability at an impressive price point. The design, construction, and quality control processes that DT Swiss applies to these hubs is every bit as thorough as their legendary 240s series hubs.
Compared to a traditionally-spoked hub, these straight-pull hubs allow for increased spoke life by eliminating the spoke's j-bend, while reducing overall weight and increasing aesthetic appeal. While straight pull hubs limit spoke lacing to a single option, the spoke crossing and angles are optimized by DT Swiss for the best possible performance in real-world riding conditions.
We recommend bladed spokes be selected when building straight pull wheels as they are the easiest way to combat spoke windup. Check out the DT Spoke Calculator or contact us if you have questions on which parts to select for your next wheel build.
Weight135 grams
Bearing Sizes6902 (2)
Hub Shell Materialaluminum
Axle Materialaluminum
Axle StandardTA 15x100
TA 12 x 100
Brake Rotor Compatibilitycenterlock (6-bolt adapter included)
Recommended UseGravel/CX, Mountain, Road Disc
Wheel Building Dimensions
Left Flange Diameter38.5 mm
Right Flange Diameter36.5 mm
Left Flange to Center21.4 mm
Right Flange to Center35.1 mm
Left Spoke Hole Offset1.0 mm
Right Spoke Hole Offset0.95 mm
