DT Swiss 350 Straight-Pull Boost Disc Front Hub
$112.90
The updated 350 hub is lighter with a redesigned shell, axle, and Ratchet SL freehub, embodying reliability and simplicity. It inherits DT 240 features at a budget-friendly price, thanks to refined manufacturing. With standard bearings and a typical spoke pattern, these hubs are easily serviced. DT Swiss 350 hubs are a durable, high-performance investment.
WHEEL BUILDING
  Centerlock 6-Bolt
 Weight ~136g ~143g
 Bearing Size 6902 - (2)
 Spoke Holes 28
 Axle Standard 15 x 110mm Boost
--Wheel Building Dimensions--
 Flange Diameter Left 40.8 mm 40.8 mm
 Flange Diameter Right 36 mm 36 mm
 Center to Left Flange 27.9 mm 28 mm
 Center to Right Flange 40 mm 40.2 mm
 Spoke Hole Diameter 2.5 mm
 Spoke Hole Offset L / R 1.7 mm / 1.8 mm
