DT Swiss 350 Road Front Hub
Article number: | 024-01-04 |
The updated 350 hub is lighter with a redesigned shell, axle, and Ratchet SL freehub, embodying reliability and simplicity. It inherits DT 240 features at a budget-friendly price, thanks to refined manufacturing. With standard bearings and a typical spoke pattern, these hubs are easily serviced. DT Swiss 350 hubs are a durable, high-performance investment.
WHEEL BUILDING
J-Bend | Straight-Pull | |
Weight | ~146g | ~114g |
Spoke Holes | 20 / 24 / 32 | 20 |
Axle Standard | 5 mm x 100 mm | |
Bearings Size | 6902 - (2) | |
Brake Interface | Rim Brake Only | |
-- Wheel Building Dimensions -- | ||
Flange Diameter Left | 39 mm | 26.15 mm |
Flange Diameter Right | 39 mm | 26.15 mm |
Center to Left Flange | 37.4 mm | 37.8 mm |
Center to Right Flange | 37.4 mm | 37.8 mm |
Spoke Hole Diameter | 2.6 mm | 2.5 mm |
