DT Swiss 350 Road Front Hub
$112.90
Article number: 019-05-04
The updated 350 hub is lighter with a redesigned shell, axle, and Ratchet SL freehub, embodying reliability and simplicity. It inherits DT 240 features at a budget-friendly price, thanks to refined manufacturing. With standard bearings and a typical spoke pattern, these hubs are easily serviced. DT Swiss 350 hubs are a durable, high-performance investment.
WHEEL BUILDING
  J-Bend Straight-Pull
 Weight ~146g ~114g
 Spoke Holes 20 / 24 / 32 20
 Axle Standard 5 mm x 100 mm
 Bearings Size 6902 - (2)
 Brake Interface Rim Brake Only
 Flange Diameter Left 39 mm 26.15 mm
 Flange Diameter Right 39 mm 26.15 mm
 Center to Left Flange 37.4 mm 37.8 mm
 Center to Right Flange 37.4 mm 37.8 mm
 Spoke Hole Diameter 2.6 mm 2.5 mm
