DT Swiss 350 Road Rear Hub
$284.90
Article number: 024-04-03
The updated DT Swiss 350 hub is lighter, thanks to a redesigned shell, axle, and Ratchet SL freehub. Reliability and simplicity are its core, making maintenance easy. It inherits DT 240 features at a budget-friendly price, with standard bearings and spoke pattern for easy servicing. Opt for the 54-tooth ratchet for quick engagement or the Rapid Drive rings for a performance boost.
WHEEL BUILDING
Trust a skilled wheelbuilder for DT Swiss hub wheels. Please contact us for expert service and rim/spoke advice.
  J-Bend Straight-Pull
 Weight ~238g ~232g
 Spoke Holes 24 / 32 24
 Axle Standard 5 mm x 130 mm
 Bearings Size 6902 - (2)
 Brake Interface Rim Brake Only
 Freehub Body Options Shimano 11 / SRAM XDR
 Freehub System 36t SL Ratchet
 Flange Diameter Left 46 mm 38.7 mm
 Flange Diameter Right 46 mm 46.2 mm
 Center to Left Flange 34.1 mm 33.9 mm
 Center to Right Flange 16.3 mm 15.3 mm
 Spoke Hole Diameter 2.6 mm 2.5 mm
 Spoke Hole Offset L / R   1.8 mm 0.4 mm
