DT Swiss 350 J-Bend Disc Front Hub
Article number: | 024-01-04 |
The updated 350 hub is lighter with a redesigned shell, axle, and Ratchet SL freehub, embodying reliability and simplicity. It inherits DT 240 features at a budget-friendly price, thanks to refined manufacturing. With standard bearings and a typical spoke pattern, these hubs are easily serviced. DT Swiss 350 hubs are a durable, high-performance investment.
WHEEL BUILDING
Centerlock | 6-Bolt | |
Axle Standard | 12 / 15 x 100mm | 15 x 100mm |
Weight | ~138g | ~158g |
Bearing Size | 6902 - (2) | |
Spoke Holes | 24h / 28h | 28h / 32h |
--Wheel Building Dimensions-- | ||
Flange Diameter Left | 44 mm | 60 mm |
Flange Diameter Right | 44 mm | 44 mm |
Center to Left Flange | 22.4 mm | 22.4 mm |
Center to Right Flange | 35 mm | 35 mm |
Spoke Hole Diameter | 2.6 mm |
