DT Swiss 350 J-Bend Disc Rear Hub
$284.90
The updated DT Swiss 350 hub is lighter, thanks to a redesigned shell, axle, and Ratchet SL freehub. Reliability and simplicity are its core, making maintenance easy. It inherits DT 240 features at a budget-friendly price, with standard bearings and spoke pattern for easy servicing. Opt for the 54-tooth ratchet for quick engagement or the Rapid Drive rings for a performance boost.
WHEEL BUILDING
Trust a skilled wheelbuilder for DT Swiss hub wheels. Please contact us for expert service and rim/spoke advice.
  24 hole 28 hole / 32 hole
  Centerlock Centerlock 6-bolt
 Weight ~244g ~253g ~273g
 Bearing Size 6902 - (2)
 Axle Standard 12 x 142 mm
 Freehub Body   Options Shimano 11 / SRAM XDR Shimano 10 / SRAM XD
 Freehub System 36t SL Ratchet
--Wheel Building Dimensions--
  Centerlock 6-bolt
 Flange Diameter Left 47 mm 60 mm
 Flange Diameter Right 47 mm 50.5 mm
 Center to Left Flange 33 mm 33.6 mm
 Center to Right Flange 20.2 mm 20.4 mm
 Spoke Hole Diameter 2.6 mm
