DT Swiss 350 J-Bend Boost Disc Front Hub
$112.90
The updated 350 hub is lighter with a redesigned shell, axle, and Ratchet SL freehub, embodying reliability and simplicity. It inherits DT 240 features at a budget-friendly price, thanks to refined manufacturing. With standard bearings and a typical spoke pattern, these hubs are easily serviced. DT Swiss 350 hubs are a durable, high-performance investment.
WHEEL BUILDING
  Centerlock 6-Bolt
 Weight ~143g ~165g
 Bearing Size 6902 - (2)
 Spoke Holes 28 / 32
 Axle Standard 15 x 110mm Boost
--Wheel Building Dimensions--
 Flange Diameter Left 44 mm 60 mm
 Flange Diameter Right 44 mm 44 mm
 Center to Left Flange 27.4 mm 27.4 mm
 Center to Right Flange 40 mm 40 mm
 Spoke Hole Diameter 2.6 mm
