DT Swiss 240s Straight Pull Road Rear Hub
$426.90
The bike mechanic's yardstick for measuring the durability and serviceability of all hubs has long been the 240s by DT Swiss. Practically indestructible and incredibly smooth, the 240s certainly deserves such a title. Now available in a straight pull option for those looking to save a few grams and obtain a slight increase in aerodynamics. The DT Swiss 240s Straight Pull will quickly prove to be one of the best investments you can make for your bike.
The 240s Straight Pull Road rear hub is available in 24 spoke hole count only, with options for either a Shimano 10/11 or Campagnolo freehub body.
Wheel Building
We recommend that wheels with DT Swiss hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections.
Bearing Size6902 (2), 6802 (2)
Recommended UseRoad
CompatibilityShimano/Sram 9/10
Shimano 11
Campagnolo 9/10/11/12 (with proper freehub body)
SRAM XDR (with proper endcaps)
Weights
24 Hole, Quick Release212 grams
Wheelbuilding Dimensions*
Left Flange Diameter38.5 mm
Right Flange Diameter45.5 mm
Center to Left Flange33.3 mm
Center to Right Flange15.8 mm
*Use only straight pull spokes, laced 3x
