DT Swiss 240s Road Rear Hub
UPC:
Default Tax Class
$426.90
DT's venerable 240s hubs have achieved a near-legendary status with a decade of production and heavy use by many of the industry's top wheel manufacturers, including Enve, Reynolds, and Bontrager. The 240s has defined itself as a mechanics' favorite; an extremely durable and dependable hub, with a lightweight, easily serviceable design.
DT's 240s rear hubs feature their precision star ratchet engagement system, which is both strong, quiet (when properly lubricated), and user-serviceable. This system differs dramatically from the common spring-and-pawl designs, which have many small parts that are susceptible to premature wear or breakage.
Wheel Building
We recommend that wheels with DT Swiss hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild
Manufactured in Switzerland
Weight, Shimano 220 grams
Weight, Campagnolo 210 grams
Bearing Sizes 6902 (2), 6802 (2)
Axle Diameter 15 mm
Available Drillings 24, 28, 32 hole
Hub Shell Material Aluminum
Drive Ring Material steel
Wheel Building Dimensions
Left Flange Diameter 45 mm
Right Flange Diameter 45 mm
Center to Left Flange 32.6 mm
Center to Right Flange 16.9 mm
Rear Rim Brake Hubs
Fits:
24h
Fits:
28h
Fits:
32h
Style:
Road
Diameter:
QR 130
Freehub Body:
Shimano Road 11
Freehub Body:
Campagnolo
Freehub Body:
SRAM XDR
