With Boost frames becoming more readily available many manufacturers are having to scramble to accommodate the ever expanding market for aftermarket hubs.
DT Swiss has been manufacturing high quality hubs for decades and for every cycling discipline. Their flagship design has been their 240s line of hubs with good reason. Simple construction and unsurpassed quality have made this hub the choice of wheel builders and avid cyclists alike. With a slight tweak to the flange placement and size, the 240s Boost hub offers proven dependability for riders running the latest model frames. Retaining the same quality and durability as previous generations, Boost hubs have a wider stance allowing for a laterally stiffer wheel. With longer travel, more aggressive trail bikes stiffness becomes a must. Recent improvements to suspension technology have dramatically increased rear end stiffness and wheel tracking. All this is for naught if the rear wheel flexes under hard cornering. Ideal for riders choosing the more aggressive trails, these benefits are no less utilized in the XC and lighter duty fields. With standard sized sealed cartridge bearings and j-bend spokes these hubs can be serviced by most shops and home mechanics with commonly available tools and parts. Pair your 240s with a set of DT 54 tooth ratchets for nearly instant engagement. The perfect choice for riders who demand the most of their equipment DT 240s hubs offer dependability throughout the season no matter the riding conditions.
Backed by DT’s 2 year warranty against materials and workmanship defects, 240s are the ideal choice for riders looking to built a lightweight durable mountain wheelset.
Flange Diameter Left | 44 mm |
Flange Diameter Right | 47.5 mm |
Center to Flange Left | 36 mm |
Center to Flange Right | 22.4 mm |
Weight | 232 grams |
